Interesting point that David, about the 4-way having a 5th hole.
I had understood that there was indeed a true 5-way connector, as seen here :
https://www.thebonnevilleshop.com/produ ... pn-850832/
but maybe they were in fact not in use in 1962.
https://classiccarparts.co.nz/bullet-co ... ation-3570
I'm puzzled by your interpretation of the diagram you have shown, as the famous Coventry Auto booklet sold by Autosparks, showing a detailed breakdown of the different circuits, seen above and below, ties in perfectly with their loom.
The Autosparks Series 1 loom has 6 wires going to the wiper motor, which is April 1962.
Harness : Red/Green - Yellow/Green - White/Green - Brown/Green - Blue/green - Green
Motor : Red/Green - Yellow/Green - White/Green - Brown/Green - Blue/Green - Green/Black
(the earth on the motor is direct/separate and not in the loom)
My understanding is that the switch is on the
right of your diagram (which is why the poles are numbered, as is the switch) and has 5 wires plus an earth, with the motor on the
left of the diagram, having 6 wires plus an earth that is not shown.
The title should perhaps have read Screenwiper Motor and Switch ?
