It is more like a little hickup at 1500.
When I move the pedal rather gentil until I am over 1500, then it is fine.
During cruising on normal streets around 2000-2500, it then is to fat. Lambda readings are around 10-11.
Throttle is almost closed, so the Webers are still running on the idle circuit + some of the prog. holes.
But when I make it leaner here to 12-13 and accelerate, lambda goes to 14-16 and the car stalls. Already tried 55F8, 60F4, 60F14.
So I kept the 60F8 with a cruising setup a little to fat, but it works.
Thought the 5 holes might help here.
This is my actual setting:
Idle jet 60F8
Main jet 140
Air correction 180
Emulsion tube F7
Choke 36mm
Auxiliary venturi 4.5
Pump jet 45
Pump spill 40
