Both doors are a bit too wide to fit inside the door. Especially, the left door. After some modifications to the door I have managed to squeeze it in, but the cut-out in the frame is resting on the door which has cracked the paint... is this section supposed to fit inside the door, or is it supposed to be ground / cut to be over the door? please see the images and maybe share your own if you have any.
My doors are new and the chrome has not been installed in these doors before. The door and car are painted, so I don't want to cut in it, but the frame will need to be re-chromed. Hence, I can and have already done some modifications to it.
And is the stud / bracket which holds the window frame in place identical for both the front and rear? the length do seems to be different with some margin.
Any help / photos of general LWB window frames would be much appreciated to help with the installation.
