Marek - thanks for the drawing. Not quite sure I understand it as there are no measurements. Are you suggesting that the distance from the carbon face to the centre of the thrust arm hole should be approx twice the distance as the distance shown on the diaphram drawing.
just to let you know - the garage cleaned up the bell housing when I last got there and things looked encouraging. But get this, never heard of it before - when they checked out the new clutch it was literally fixed in the forward position and had to be forced off the centre of the diaphram opening. Looks as though the first push of the pedal virtually welded the clutch in the forward position. Had to be forced free. Weird.
Thanks again for the help. I'm going back on monday so will check that Marek's drawing matches the distances on the new setup, assuming they have had a new clutch delivered as it looked as though the new one had been damaged around the hole in the centre.
Hope I'm not being a pain, I'm not an engineer so don't always understand everything.
Ray
