Trafficator switch
#1 Trafficator switch
Hopefully someone can assist me in my quest...
There is a part missing from my original switch that would operate the dash indicators. Would someone have any pictures of the missing part as i hope to reproduce it and get my switch back in operation.
I made the error of purchasing a new switch which does not fit the die cast housing, so I am hoping to repair the old switch...
Thank you in advance,
Mike
Mike
#3 Re: Trafficator switch
Mine looks like this:
Nylon available from SNGB:
https://www.sngbarratt.com/English/#/UK ... dicator%60
1965 S1 4.2 FHC (early)
#4 Re: Trafficator switch
#5 Re: Trafficator switch
Does this video help at all, supposedly from 1963 model? Jump to 5:31 for rebuild;
#7 Re: Trafficator switch
Neat video, but for the later version of the switch (part # C21710). Mine is a part # C16069
I'm assuming that a proper (original) Lucas C21710 would fit in place of the C16069?
#8 Re: Trafficator switch
That is it! So it looks like two brass "wings" belong on the upper switch...
#10 Re: Trafficator switch
Correct.
Unfortunately, this one does not fit into the die cast housing that goes over top...
#11 Re: Trafficator switch
SNGB also lists C25254 for 4.2 E Type which looks like it’s for later cars. My 1965 (early) 4.2 has the C21710 type original version.
#12 Re: Trafficator switch
Another article to compare:
https://www.jaguarforums.com/forum/mki- ... em-263082/
Are you certain your stalk is correct to the car and not an adapted S Type for example?
#13 Re: Trafficator switch
I am assuming it is correct as it is dated 10/62 which is the month of manufacture of the car.
100% sure? No...this car had a lot of interesting repairs...
However the switch is not like the link just sent in post #12, it is like the one in post #6.
Thanks,
Mike
Thanks,
Mike
#14 Re: Trafficator switch
Fashioned a couple of "wings" out of stainless steel. I now have ground for the dash indicator wires, so the should work now.
#15 Re: Trafficator switch
