Hi all. Lots of good tips!. Not had cause to remove mine as yet but the time will come.
Incidentally Tim...I see you are in Leighton Buzzard.....I am near Hemel!
Inlet manifold gasket
#21 Inlet manifold gaskets.
Hello Steve,mgcjag wrote:Hi Emmanuell.....either gasket should be ok....are both surface nice and smooth, manifold and engine.....use thin smear of sealer on all mating surfaces...my preference is Well seal.....
Thank you for the advice. It's clear for me.
I just ordered a 500ml can of wellseal.
#23 Re: Inlet manifold gasket
I see that I’ve posted before on but now I’m on a different car and am faced with the same decision on which inlet manifold gasket to use.
I’ve spoken to Rob Beere who could be relied on to know his stuff !
The recommendation was the cometic gasket without any sealer.
Just make sure that the surfaces are flat and square. The head has been done by CMES and I’ve going to have the manifold checked out.
Will respond with how I get on but it will be a few weeks ( it’s bloody cold in the garage ! )
