Hi all,
after having traced water ingress (liners), it was decided to rebuild the engine. Now I am about to start the assembly. My first question (of quite a few to come I suppose) is:
timing chain guides adjustment: the special tool from Rob Beere is rather expensive - is there another way to adjust the guides to avoid a rattling chain?
Thank you
#2 Re: timing chain guides adjustment
On the basis that the ones you have at the moment are original and in the right place, replace like with like by putting a shim in against the chain between the ungouged part of the guide and the chain and score the front of the block with a scribe. Other than that, the special tool would be the only other way and it is doing exactly the same job anyway.
#3 Re: timing chain guides adjustment
Thank you Marek,
I missed that chance, should have known better
nevertheless thank you very much for your support
1963 OTS 880436
1963 OTS 880436
#4 Re: timing chain guides adjustment
Hi Mark
I dont know what price the Rob Beare tool is but they come up for sale on eBay and i believe SNG and others also sell them….have a look around…second hand is just fine
Best
Jonathan
Best
Jonathan
