Dear All,
I was wondering if 2 Re Shocks per wheel is std on all E Types.
Also any idea on adjustements ?
https://skydrive.live.com/P.mvc#!/?cid= ... &sc=photos
My Rear Shocks
PAUL MORRIS
Topic author - Posts: 344
PAUL MORRIS
Hi Paul.......The links you have posted only take me to a sign in page for windows skydrive?..........2 shocks per side on the rear are standard on e Types & adjustments can only be made to adjustable type shocks (Gaz/koni etc) standard type are non adjustable.....Steve
PAUL MORRIS
I have Gas Koni type with the adjust, I was wondering how to judge
the proper setting
the proper setting
Hi Paul........Its really down to whether you want a hard or soft ride & trial & error...as far as I,m aware the adjustable konies cannot be adjusted whilst attached to the car & have to be either disconnected or removed....all the best Steve
PAUL MORRIS
Dear Steve,
On the Shocks you have a + & - Knob, not sure which is hard or soft
https://skydrive.live.com/?cid=409d34c9 ... &sc=photos
Hi Paul
+ is a firmer ride (normally). Normally notched so best to start at one end of notch range and select equal number of notches per shock.
John H
John H
