Guy broadspeed
Paul bow
#1 Guy broadspeed
Post by Paul bow » Fri May 24, 2024 9:47 am
Hi guys.. after reading much on here about the 5 speed scenario, and all the different options, I was hoping someone could give me some feedback on the guy broadspeed box.
It looks like a pretty much swap out, got some tours planned in September and even though I run a 3.07 diff 2900 rpm at 70, for hundreds of miles i think it could really do with the 5th gear..
Any help gratefully received before I spend my money
Nb it a 4.2 ots
S1 2+2 manual. (Sold)
#2 Re: Guy broadspeed
Post by DWW » Fri May 24, 2024 12:03 pm
I have this from Guy Broad, very happy with the conversion, a lot lower rpm@70 than the 3.07 you indicate. I had mine done by them so no direct experience in the diy side of things but plenty of info here about self install.
Paul bow
#3 Re: Guy broadspeed
Post by Paul bow » Fri May 24, 2024 12:15 pm
Thanks Danny.. looking about 4.5k for them to do it, so that’s going to be a diy job for me ! 🤣
But good to hear you are pleased with it.
#4 Re: Guy broadspeed
Post by bitsobrits » Fri May 24, 2024 2:48 pm
No experience with the Broad 'box, but I do have a T5 based conversion, which with my US spec 3.54 rear gives me an effective 2.58 in 5th. The reduced rpm over long drives really helps with my wife's mood, as well as fuel mileage. 20 years on from my conversion, I wouldn't have it any other way.
If you have choices of 5th gear ratio with the Broad option, you might want to stay in the .75 to 80 range, given your present 3.07 final drive. Going numerically lower could reduce the usefulness of the conversion in normal (legal) speed ranges.
JerryL770
#5 Re: Guy broadspeed
Post by JerryL770 » Fri May 24, 2024 6:27 pm
You should read this thread viewtopic.php?f=3&t=19058&hilit=5+speed#p154225
Jerome Lunt
Paul bow
#6 Re: Guy broadspeed
Post by Paul bow » Fri May 24, 2024 10:05 pm
Thanks Jerry and Steve..
interesting read.. has gt joey now finished the conversion of the broadspeed g/box, or is this waiting to be continued??
#7 Re: Guy broadspeed
Post by bitsobrits » Fri May 24, 2024 10:56 pm
I believe he finished it year or so ago, and later sold the car. But perhaps if he is on here, he can confirm.
#8 Re: Guy broadspeed
Post by mgcjag » Sat May 25, 2024 7:23 am
Hi Paul...if you look through the whole thread you will read that Joey completed the gearbox conversion and reported on how it drove..Steve
#9 Re: Guy broadspeed
Post by abowie » Sat May 25, 2024 9:01 am
Is the Broadspeed box Getrag or T5 based?
ralphr1780
#10 Re: Guy broadspeed
Post by ralphr1780 » Sat May 25, 2024 8:53 pm
Ford cosworth.
Ralph
'69 OTS + '62 OTS - Belgium
#11 Re: Guy broadspeed
Post by bitsobrits » Sun May 26, 2024 2:50 am
I have a gearbox from an early 80's Ford XR4ti and I believe is called the type 9. Looks nothing like the Broad 'box, and has an iron main case. The euro Sierra Cosworths used either the Iron case MT-75 or the T5, depending on year.
The Broad gearbox looks a lot like a BMW spec Getrag to me.
#12 Re: Guy broadspeed
Post by mgcjag » Sun May 26, 2024 5:39 am
You all need to have a look here viewtopic.php?f=9&t=1139
Paul bow
#13 Re: Guy broadspeed
Post by Paul bow » Sun May 26, 2024 5:54 am
Loads of great info as usual on here.. many thanks guys, really appreciate the help, Steve well done for posting that link much appreciated.
