I have a '64 3.8 coupe. The brake warning light is constantly lit. The fluid level in the reservoirs is full. I remember that the light used to flicker a bit and pushing the hand brake lever down would cause it to flash off, but it would come back on. Now I can't get it to turn off at all.
I'm thinking there must be an adjustment for the contact switch (if there is one) that could be adjusted.
If I am correct, where is it and how is it adjusted?
Thank you all in advance.
