Tacho generator
WEBSTER1357
Topic author - Posts: 10
#1 Tacho generator
The tacho has stopped working on my Series 1. I removed the tacho generator at the rear of the rocker cover and spun it up with a drill and the tacho in the car works. Any ideas whats going on here? Any thoughts or suggestions much appreciated.
#2 Re: Tacho generator
Have a look here viewtopic.php?f=2&t=16474&p=135377&hili ... or#p135377
WEBSTER1357
#3 Re: Tacho generator
Thank you that's a very informative article and tapping out the armature has fixed it. Tacho now working great advice many thanks.
#4 Re: Tacho generator
The movement of the armature may be because the bush is loose.WEBSTER1357 wrote: ↑Mon Jun 03, 2024 4:23 pmThank you that's a very informative article and tapping out the armature has fixed it. Tacho now working great advice many thanks.
If it happens again that probably needs addressing.
