baldyz1
Post
by baldyz1 » Fri Jul 05, 2024 11:40 am
After some help again please.
I need to re-torque my head bolts as the engine has been started and warmed up but not used for several years and I am soon to finish the build. There was evidence of a very small bit of overboarding of water when it was first run and it has not been retorqued since then.
I have found the advice to be around 54 lbft for the main bolts numbered 1-14 (see pic) but what should the torque be for the bolts numbered 15 to 20 in the diagram shown?
many thanks
Chris
Chris C
1966 4.2 2+2 Gun Metal
tim wood
Post
by tim wood » Fri Jul 05, 2024 11:59 am
I don’t believe that any torque figure has been published for these. My head was rebuilt by CMES who supplied a copy of the torque setting and tightening sequence and method. No mention of the figures for these smaller nuts.
Tim
Post
by malcolm » Fri Jul 05, 2024 12:56 pm
I was just told to do them "reasonably tight and check now and then"
That's what I did, all seems fine.
baldyz1
Post
by baldyz1 » Fri Jul 05, 2024 1:00 pm
I will check what they are now and if they match and just tweak by a couple of lb/ft.
Many thanks
Chris
Chris C
