Senior Moment Choke Cable
andrewh
#1 Senior Moment Choke Cable
Post by andrewh » Sat Jul 13, 2024 11:41 am
Having just finished the 4.2 Restoration and in the process of shaking it down the wretched choke cable has slipped in its clamp at the dash board end! Having just got the car back from the trimmers I am not best pleased to have to contemplate removing the dash top to get at it. But my question is, because I cannot recall exactly, if I do remove the dash top is that going to effect me access to rectify the issue? I did think about access from underneath but the under dash panels are so expertly fitted I feel reluctant to mess with those if the dash top will suffice. Of course I may have an issue feeding the de mister pipes back into their places without the under dash panels being removed but I shall tackle that if the problem presents itself. And I thought all was done and complete!
photo for attention
1962 3.8 Series One FHC
Robbiee
#2 Re: Senior Moment Choke Cable
Post by Robbiee » Sat Jul 13, 2024 1:25 pm
My feeling is that the choke cable clamp screw is best accessed from below so I would unscrew the boards under the dash
Removing the steering wheel will help access
Robbie
andrewh
#3 Re: Senior Moment Choke Cable
Post by andrewh » Sat Jul 13, 2024 1:34 pm
Thanks Robbie. I just cannot quite recall how much the lower return on the dash panel obscures the working room. Perhaps someone here has a photo with the dash top off ?
Robbiee
#4 Re: Senior Moment Choke Cable
Post by Robbiee » Sat Jul 13, 2024 1:59 pm
The return is not too deep
Here’s some photos
I still think it’s much easier from below!😊
Robbiee
#5 Re: Senior Moment Choke Cable
Post by Robbiee » Sat Jul 13, 2024 2:00 pm
And this:
andrewh
#6 Re: Senior Moment Choke Cable
Post by andrewh » Sat Jul 13, 2024 2:13 pm
thanks again Robbie. Its certainly easier to get at the inner clamp with the top off. Its not great working in an inch width upside down at my age!!!! :bigrin:
#7 Re: Senior Moment Choke Cable
Post by abowie » Sat Jul 13, 2024 11:46 pm
Take the tacho out.
#8 Re: Senior Moment Choke Cable
Post by mgcjag » Sun Jul 14, 2024 7:29 am
:yeahthat: but you have to remove your under panels..Steve
andrewh
#9 Re: Senior Moment Choke Cable
Post by andrewh » Sun Jul 14, 2024 7:35 am
Ok Guys. Thanks for the help. I will get the under panel off and look at the scene. Will report back. :thankyouyellow:
andrewh
#10 Re: Senior Moment Choke Cable
Post by andrewh » Tue Jul 16, 2024 11:33 am
Ok, well by way of a sign off the job is done, but its a pain in the posterior. Removing the dash under panel was easy, I was confused as it looked like it was a one piece going right the way over to the Hazard switch which itself was a complete pain to fit. Anyway, one screw and the under panel came away. This gave visual access to the problem but its was extremely difficult to feed the inner cable back into the trunnion when up in side the dash. Removing the RPM counter would not have improved that access as the choke cable is the other side of the bracket that supports the lever mechanism . I removed the upper trunnion and the outer cable lock and then fitted the trunnion onto the cable and replaced it in the lever. If you are about 5 ft 2 inch and a contorsionist who can focus on items about 6 inches above your head in the dark then it will be easy. For me it was a challenge but certainly do able without removing the dash top. Thanks for the all the advice as always. Andrew
#11 Re: Senior Moment Choke Cable
Post by DWW » Tue Jul 16, 2024 12:15 pm
Well done and now a useful resource 👍
#12 Re: Senior Moment Choke Cable
Post by malcolm » Wed Jul 17, 2024 8:32 am
I've got a Granddaughter who fits that description and is available for a reasonable rate.... :bigrin:
Robbiee
#13 Re: Senior Moment Choke Cable
Post by Robbiee » Wed Jul 17, 2024 10:29 am
I have a Seamstress for a wife and 5ft 2inches with excellent fine motor skills and special awareness ..does the underdash stuff with no effort
Glad our advice helped !
