I know its a fairly well discussed topic, but was after a few learned opinions.
I'm in the process of re-assembling my car and decided to have a go putting the windscreen in on my own. I've had two attempts, both resulted in the windscreen going in, but both times the whole thing ended up very tight. Hopefully the picture will attach and you can see my problem, ie there is very little room for the sealing strip, especially in the corners, but along the long sides too.
The windscreen is the cars original screen, no welding was done to the body so no change to the screen aperture either apart from the thickness of a little paint. So I'm pointing the finger of blame at the windscreen rubber.
Has anyone else had this problem?
I can't imagine there are many different people manufacturing e-type windscreen seals? Although lots of companies sell them.
Thank you for any thoughts.
