Where does this go?
dmarsh2426
#1 Where does this go?
Post by dmarsh2426 » Sat Jul 26, 2025 3:43 pm
I have refurbished my 4 speed gearbox in my '67 OTS: new bearings, new companion shaft, new thrust washers, new seals, and new synchros. I have reassembled it and it seemed to shift fine. It is back in the car now.
The other day, under my workbench I found a small spring. It is smaller and less dense than the detent springs as seen in the second photo. It is tapered as well.
I dont remember seeing other springs like this while I was rebuilding the gearbox.
It is almost the size of a spring from a ballpoint pen, but is heavier.
Needless to say, I do not look forward to removing the engine and gearbox again, but I guess I will have to if this is indeed integral to a functioning gearbox.. :banghead:
Dan
Paul bow
#2 Re: Where does this go?
Post by Paul bow » Sat Jul 26, 2025 7:34 pm
Well I’m afraid I do not know the answer to that but certainly know a very helpful Ken at klassic English transmissions, who as said very helpful and knows more about these g/boxes than anyone should do ..
find his number below if you get no answers from the others on here…hope that helps.
07801 882771.
4.2 Semi Lwe, steel tub (best car I’ve ever had !)
4.2 ots (sold)
3.8 (sold)
4.2 2+2 (sold)
dmarsh2426
#3 Re: Where does this go?
Post by dmarsh2426 » Sun Jul 27, 2025 12:18 am
Great, thank you. I will give him a call.
#4 Re: Where does this go?
Post by abowie » Sun Jul 27, 2025 4:06 am
I don't recall any springs inside the gearbox that look like that.
I can only assume that one end of the wormhole that eats springs in my workshop exits under your bench...
dmarsh2426
#5 Re: Where does this go?
Post by dmarsh2426 » Sun Jul 27, 2025 1:14 pm
I wondered where those have been coming from!
I may have some of your washers too.
angelw
#6 Re: Where does this go?
Post by angelw » Mon Jul 28, 2025 10:32 pm
Hello Dan,
For absolute certain, that spring didn't come out of your gearbox, unless someone during previous work, inadvertently dropped this foreign item into the gearbox.
dmarsh2426
#7 Re: Where does this go?
Post by dmarsh2426 » Sat Aug 02, 2025 2:39 am
Thank you
