I thought I'd investigate why the wire might have burnt out before going any further, and checked the HT lead from the coil to the dizzy cap. On removing it at the coil (acorn screw-in type) it appears that the brass disc is missing which might have increased resistance causing it to overheat?
Long story short, I've decided to replace the whole lot as I had planned to upgrade to electronic ignition once the car was up and running anyway. Probably looking at a bluetooth 123, new coil and new leads. Looking at the old coil, there are 2 wires connected to the "SW" side - one switched 12v, and a green wire that runs through a small cylindrical object to ground. When I check continuity, there is continuity from this side of the coil to ground, despite this being the 12v input side. I always assumed the small cylindrical object was a ballast resistor, but it doesn't look like any pics of ballast resistors that I see online:
Am I missing something or being stupid here? With electronic ignition, I presume I don't need a ballast resistor anyway?
