Post
by angelw » Fri Jan 23, 2026 1:47 pm
Hello Andrew,
Yes, it will change the heat treated state of the material.
Take the part to a heat treatment plant, or anyone you may know with a hardness tester, to establish the heat treated state before you start heating it. Then have it heat treated again after heating and reshaping it.
If the heat treating oven is tall enough, ask that it be hung vertically. Failing that, the part would have to be well supported during the heating stage.
