Clutch Release bearing - is the roll-pin OK ?
#1 Clutch Release bearing - is the roll-pin OK ?
I'm about to replace my clutch release bearing. It has done 15 years and 25K miles, but the carbon material has worn away. I note that the release bearing supplied with the Borg & Beck clutch (I may as well replace the clutch at the same time) has a small dia. roll pin pressed in from the side to secure the carbon in position. I've read on the forum of some previous failures and a roll pin, rather than a shrink fit into the housing as per the original design, doesn't seem very reliable to me.
Are there any recent experiences ? I'm considering running some superglue around the joint between the carbon & the steel housing.
Thanks.
Thanks.
1965 S1 FHC
#2 Re: Clutch Release bearing - is the roll-pin OK ?
We’ve just replaced mine with the rob beere upgrade. Really good so far. I just don’t have any faith in the modern carbon bearings any more - seen too many breaking up/coming loose.
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
#3 Re: Clutch Release bearing - is the roll-pin OK ?
It's a lot of work if you get it wrong....last couple I did were NOS bearings....they do come up on ebay but make sure they are the old ones and not NOS from a couple of years ago....I wouldnt touch the ones with roll pin or the self tap screw....I would go the same route as Angus...iv heard a couple of reports on them with no issues yet...Steve
#4 Re: Clutch Release bearing - is the roll-pin OK ?
Thanks for replies gents. I've sourced an older carbon bearing to have available as an alternative.
Nick
Nick
1965 S1 FHC
#5 Re: Clutch Release bearing - is the roll-pin OK ?
Thete are several different release bearings..ensure that you have the correct one....have a look at this photo and note the difference in the main body from pivot point....yes one is worn but you can see the difference....Steve
#6 Re: Clutch Release bearing - is the roll-pin OK ?
Thanks. The ebay old stock version is the same size (apart from assembly differences) as the new one supplied by Barratt's with the 4.2 diaphragm clutch. In the new bearing there was a 0.0015" gap in places around the circumference. The old one didn't have a gap here, but there is a 1-1.5mm gap on the rear face- ie it isn't fully seated into the recess. I currently think I'll use the old one since it doesn't have the roll pin.
The roll pin must surely have been added in an attempt to prevent the bearing rotating, but I've yet to find anyone with any engineering understanding who thinks it's a good idea.
1965 S1 FHC
#7 Re: Clutch Release bearing - is the roll-pin OK ?
I've heard - albeit from Triumph owners - that the upgraded bearing can be noisy. Angus have you experienced anything like that?
I am just about to change the clutch on my 3.8 as well.
1963 OTS 880436
1963 OTS 880436
#8 Re: Clutch Release bearing - is the roll-pin OK ?
Mistakes are made, but clearly the engineers at the manufacturer (Borg & Beck?) believe it is a good idea.
Tom
#9 Re: Clutch Release bearing - is the roll-pin OK ?
No issues yet with the roller bearing but we are about to head off to Italy next Thursday so that will give it a good test.
61 OTS 875047
61 OTS 875047
#10 Re: Clutch Release bearing - is the roll-pin OK ?
Angus, I hope you have better luck with your luggage this time! Have a great time.
#11 Re: Clutch Release bearing - is the roll-pin OK ?
Thanks Geoff! Not sure what else we can do as the cars are so easy to break into.
61 OTS 875047
61 OTS 875047
#12 Re: Clutch Release bearing - is the roll-pin OK ?
Just a quick update on the Rob Beere release bearing. Now completed over 6K miles with no issues whatsoever. The clutch feels really smooth. We will only fit these moving forward.
61 OTS 875047
61 OTS 875047
#13 Re: Clutch Release bearing - is the roll-pin OK ?
Hi Angus...thats great....what model bearing is it a I believe Rob Beere has a few options....Steve
#14 Re: Clutch Release bearing - is the roll-pin OK ?
Its the 'True Central Push Clutch Release' on their website.
61 OTS 875047
61 OTS 875047
