Looking to replace the original mounts on my E type series 3 experimental model -EX102. Usual series 3 mounts are not direct replacement neither are series 2. The single shaft on the rear is short (about 1”) and the 3 holes are inline. I understand they were fitted to series 1. Does anyone have new olds stock or no supplier as I would like to keep as original as possible.
Many thanks
Hi Simon....I think these mounts were used on the very early S1 racks?......interesting ....there must be a solution as lots of early cars have been restored....if you cant find replacements then...could you modify S2/3 mounts to fit....or consider making solid mounts.....Steve...ps have flagged this to someone who may know...
The series 2 is similar in look but the size is different and has a longer thread. The 3 is correct dimensions but curved ends. Seems I’ll have to go for these unless I order 1200 from the manufacturer….
If you AI Jaguar experimental EX102 you will get quite detailed info. It is one of 4 produced, the only LHD, has series 3 suspension, cooling , brakes and bonnet. The scope on the front is smaller than the manufactured series 3. A lot of the metal work on the bulkhead is hand welded. Brake ducts similar. USA rear prop ratio. Did have emissions fitted. All paper work from 1976.
