Can anyone help with a picture of the correct orientation for the solid brake pipe (RH cars) which runs along the front bulkhead i.e. connects the Servo with the Master C33904?
On my car, the pipe sits below the two solid vacuum lines and I believe the correct orientation should be above these pipes. What I'm not sure of is the direction below the wiper motor, is it flush with the bulkhead, or protrudes outwards as indicated in the parts manual?
I have searched on the net, but can't find anything.
Any help is appreciated.
Andrew
