Reaction plate question
#1 Reaction plate question
Post by Gfhug » Tue Jul 14, 2026 5:43 pm
It seems strange to me that the lobes on the reaction plate have holes of greater diameter than the 1/2 inch bolts that secure it to the chassis. Obviously something to do with how the reaction plate works. But when tightened up those bolt heads are not neatly pressing on the lobes as that depends on the alignment of the plate to the chassis and to the engine frames, the action of the torsion bars, etc.
Can anyone enlighten me, please?
Thanks, Geoff
#2 Re: Reaction plate question
Post by mgcjag » Tue Jul 14, 2026 6:31 pm
After market or original parts...?.... to be honest iv never looked too close....just bolted it up....however there needs to be some give to get the bolts in place but they should tighten up flush...Steve
#3 Re: Reaction plate question
Post by Gfhug » Tue Jul 14, 2026 7:30 pm
Original parts, well the bolts are new :bigrin: but the correct diameter
#4 Re: Reaction plate question
Post by abowie » Wed Jul 15, 2026 12:57 am
They’re usually a good fit. Are you sure you don’t have M12 bolts by accident?
#5 Re: Reaction plate question
Post by Gfhug » Wed Jul 15, 2026 7:19 am
Hello Andrew, correct bolts, not M12. I’d say the fit is not as snug as a normal bolt through a fitting, but not flapping loose. The project car’s reaction plate fit is the same. I’m not worried, just interested. Thanks for the responses.
#6 Re: Reaction plate question
Post by mgcjag » Wed Jul 15, 2026 7:38 am
Hi Geoff....you can use shim stock....very thin in various thicknesses steel cut to size to create a sleeve.....Steve
angelw
#7 Re: Reaction plate question
Post by angelw » Wed Jul 15, 2026 8:14 am
Hello Geoff,
The bolts are a reasonable fit in the holes in the chassis rails, through which they pass, and the reaction plate is positively located with the engine frames, via the spigot on the tear drop shaped lug than has the internal spline. Accordingly, the fit of the bolt in the tube that's welded to the reaction plate is not all that important.
I agree that it would have been nicer to have a better fit, but it has no bearing on the operation of the torsion bars.
#8 Re: Reaction plate question
Post by Gfhug » Wed Jul 15, 2026 9:01 am
Bill, thank you, that helps a lot and I can now finish tightening things up.
