Notched washers for wiper motor mounting
rdaustin
#1 Notched washers for wiper motor mounting
Post by rdaustin » Sat Aug 01, 2026 5:13 pm
Just re-assembling the wiper motor / mounting plate. We have the 3 rubber grommets and 6 washers, 3 of which have small notches cut out of them. Does anyone know why and where they should therefore be fitted? I assume there's a washer each side of the mounting plate, but don't know where the notched vs non-notched washers go relative to one another, or where each notch should be relative to the mounting plate (eg at 3 o'c clock, 9 o'clock or....?.
(Yes, am learning the hard way about not taking enough photos during dismantling).
Also, we only have 2 of the 3 cheese head bolts that secure the mounting plate to the motor - does anyone know the part number? Can't find anything on the usuals...
Rebecca
S1 4.2 OTS RHD 1965 (UK original)
#2 Re: Notched washers for wiper motor mounting
Post by mgcjag » Sat Aug 01, 2026 6:05 pm
If you put your car model in the signature area it would help.....what is the part numberr in Jag parts catalogue for the screw?
rdaustin
#3 Re: Notched washers for wiper motor mounting
Post by rdaustin » Sat Aug 01, 2026 6:39 pm
Hi there
Good idea re: signature - now done.
I don't have the parts catalogue I'm afraid, so can't find the screw part #.
Have tried trial-fitting the mounting plate and motor together, putting a washer either side of the grommet, and cannot see why and where the notch would need to be.
Any insights welcome
Rebecca
#4 Re: Notched washers for wiper motor mounting
Post by mgcjag » Sat Aug 01, 2026 9:01 pm
We have all the catalogues in the Knowledge base section....Steve ps unfortunatly this dosnt show the 3 screws fixing motor to plate maybe these were part of the motor unit
#5 Re: Notched washers for wiper motor mounting
Post by Gfhug » Sun Aug 02, 2026 8:03 am
Do you have a parts catalogue from SNG Barratt? Almost every part is shown in there, ok some little items like these may not be shown, but it is a very useful guide to how parts are assembled and how many parts are needed with their parts numbers shown.
