Squealing V12 engine HELP!
coalboy
#1 Squealing V12 engine HELP!
Post by coalboy » Mon Aug 03, 2026 5:08 pm
Well trying to get my car fully shipshape but have a high pitched squeal after recommissioning the engine. Ok the belts are a likely culprit I thought, but had the belts off the alternator, then steering pump, then air pump and therefore the water pump and still the squealing. Anything else anyone can think off, seems louder on the LH side of the engine bay. The rad fans are obviously not turning, just thought while typing this the heater fan unit is that side of the engine bay.
All ideas welcome. Hope it’s nothing internal
S3 OTS lavender blue
#2 Re: Squealing V12 engine HELP!
Post by bitsobrits » Tue Aug 04, 2026 12:11 am
Flywheel against the metal cover plate on the bellhousing?
Is the squealing somewhat muffled (as it would be for an internal issue)? Or more of an 'external' sound?
coalboy
#3 Re: Squealing V12 engine HELP!
Post by coalboy » Tue Aug 04, 2026 12:01 pm
Sounds more external than internal too me will eliminate heater motor today and look towards the rear of the engine as a possible source
coalboy
#4 Re: Squealing V12 engine HELP!
Post by coalboy » Wed Aug 05, 2026 7:01 am
Ok the heater fan was a long shot not that, after turning off the engine the squeal subsides and there is a sound like a balloon deflating, wonder if I have an exhaust leak?
John37
#5 Re: Squealing V12 engine HELP!
Post by John37 » Thu Aug 06, 2026 11:19 am
Vacuum leak to servo or distributor?
Your's sounds like a US spec engine. My UK engine doesn't have an air pump. Is there exhaust recirculation?
It's unlikely to be an exhaust leak unless your system is almost completely blocked.
coalboy
#6 Re: Squealing V12 engine HELP!
Post by coalboy » Thu Aug 06, 2026 6:06 pm
Thanks for the suggestions. Disconnected the servo and reservoir and bunged the inlet manifold port, no elimination of the squeal,got my stethoscope on the distributor couldn’t hear it coming from there or from the black inlet manifolds.
Still to check the rest of the vacuum lines, mine is a later UK engine so has the air pump but not all the recirc stuff. Onwards I go. See what tomorrow brings.
chris420sa
#7 Re: Squealing V12 engine HELP!
Post by chris420sa » Sat Aug 08, 2026 12:00 pm
Hi there
The squeal could perhaps be from the power steering system itself, not the belt drive to the PS pump.
That could result from a number of causes eg low TQF fluid level in the reservoir (test when hot but watch out for hot surfaces nearby), which may be caused by leaks in the PS (pipework...etc.)....
I had something which sounded similar to your squeal and fixed it only by a rebuild of the PS. I can point you in the direction of a guy who has spent 40 years renovating steering racks in his workshop near Chatham. The rack is a real bugger to get back in place especially as the pipework routing sucks.On this forum a contributor said he'd removed and replaced his PS rack without removing the radiator - impossible in my experience!
Good luck and please keep us posted.
Best
Chris
Chris Davies
1972 Series 3 2+2
