Tolerance for rear wheel bearing..
Paul bow
#1 Tolerance for rear wheel bearing..
Post by Paul bow » Sun Jan 18, 2026 11:23 pm
Hi guys, so doing a bit of upgrading on the e type 69ots.
Noticed a bit of play on the rear wheel at the hub area.
So holding the wheel (car in the air) at top and bottom (6 o’clock) I have 2mm of play in the wheel pulling from the top and pushing at the bottom..
My question is without stripping down and doing the end float business on the hub, would that sound like it’s within tolerance.
This car is not on splined hubs but D type alloys and studded.
I measured the 2mm by a long steel rule vertical fixed to the wheel, and using another attached to the bodywork at a right angle.
S1 2+2 manual. (Sold)
#2 Re: Tolerance for rear wheel bearing..
Post by bitsobrits » Mon Jan 19, 2026 1:05 am
2mm is just under .080". That seems high to me. How does the other side compare?
Paul bow
#3 Re: Tolerance for rear wheel bearing..
Post by Paul bow » Mon Jan 19, 2026 6:30 am
The other side is exactly the same..only had it all rebuilt 2500k ago, by a very well known specialist in the jaguar irs field. Never checked it then, just noticed it now.
#4 Re: Tolerance for rear wheel bearing..
Post by mgcjag » Mon Jan 19, 2026 8:29 am
Hi Paul the correct way to measure is with a dial guage..the in/out movement......if doing it by hand then you should just be able to feel a very slight movement if it was set to service manual spec...to me 2mm sounds way too much....there is a lot of discussion re how taper bearings should be set up either with end float as per the service manual spec or with pre load....personally I set mine to 0(zero).....Steve....shouldn't be difficult to re set ..just measure correctly...undo the castle nut and swing the hub carrier off the driveshaft....refit a measured spacer to close your bearing gap....reassemble
Paul bow
#5 Re: Tolerance for rear wheel bearing..
Post by Paul bow » Mon Jan 19, 2026 9:16 am
Thanks Steve.. good advice I’ll measure it 👍
rfs1957
#6 Re: Tolerance for rear wheel bearing..
Post by rfs1957 » Tue Sep 22, 2026 8:54 am
Good morning boys and girls.
After 1.600 kms of fast thrashing to Biarritz and back in a Rally last week, the outward leg seemingly done on each and every Tour de France mountain pass in the Pyrenees, and with repeated max attack in a lot of hairpins, I now have about 1mm of movement, at the rim, in a rear wheel bearing.
This is detectable as quite an audible, and rather dry, click, when you grasp the wheel top and bottom.
I’ve not been in there for 10 years, and can’t remember much except that shimming them is counter-intuitive, so ……… do I fear the worst and change the bearings, or can I put it down to normal wear and do as Steve suggests, above, by swinging the hub off the shaft and trying a different spacer ?
#7 Re: Tolerance for rear wheel bearing..
Post by mgcjag » Tue Sep 22, 2026 11:05 am
Hi Rory.....you need to find out what's wrong.....is it the hub to hub carrier....if yes then is bearing nice and smooth....if yes then actually measure any movement....providing your splined hub isn't srized/loctited into the hub then yes undo the castle nut and pull hub/carrier forward off the shaft....measure the spacer shim.......thinner shim allowed bearing to press together more so reduce play........however you may have a UJ or driveshaft to fiff or diff o/p shaft issue....Steve
rfs1957
#8 Re: Tolerance for rear wheel bearing..
Post by rfs1957 » Tue Sep 22, 2026 2:38 pm
I remembered it as being counter-intuitive ?
I know I got it wrong at some point :scratchheadyellow:
Now I'm not so sure !
Before I get dismantling, daft question N°2 :
Does a thicker spacer in the rear hub pile indeed reduce the end-play ?
I know what the existing spacer thickness is, I wrote it down in 2022, and I seem to have noted that I need thicker to reduce the end-float.
Have an SNGB order to get in PDQ, prize for the first correct answer.
Steve ?!
#9 Re: Tolerance for rear wheel bearing..
Post by mgcjag » Tue Sep 22, 2026 2:50 pm
Hi Rory....I explained it in my previous post.. ..a thinner shim allows the bearings to be pressed together more reducing endfloat.....or increasing preload....Steve
#10 Re: Tolerance for rear wheel bearing..
Post by abowie » Tue Sep 22, 2026 11:24 pm
Rory it will be interesting to see what your measured bearing endfloat is. What you describe is 40 thou at the edge of the wheel. If you allow for the different radii this might actually put you in spec at the bearing.
Allrand
#11 Re: Tolerance for rear wheel bearing..
Post by Allrand » Wed Sep 23, 2026 6:28 am
:yeahthat: Also rock the wheel horizontaly front to back. That will elimimate reading play in the uj's.
Randall Botha
rfs1957
#12 Re: Tolerance for rear wheel bearing..
Post by rfs1957 » Wed Sep 23, 2026 12:52 pm
Get it, got it, good.
Yes, obvious now, the spacer determines how much crush the bearings feel - thinner spacer equals thrust face closer together, equals less room for the bearings, equals higher bearing load.
For some reason my inner thrust face is very neatly chewed up, so neatly that it could almost have been deliberate machining, only it was done by the fretting of the hardened spacer and the bearing track, because at some point in the past the nut wasn’t cracked down hard enough.
Edit - NOT true, bollocks even, see below.
You are right, Andrew, the rim movement corresponded to 0.15mm end float, which is not too far off spec - only my float was for the wrong reasons.
#13 Re: Tolerance for rear wheel bearing..
Post by mgcjag » Wed Sep 23, 2026 1:46 pm
Hi Rory.....was the split pin in the castle nut.....or was it missing..enabling the nut to loosen?....Steve
rfs1957
#14 Re: Tolerance for rear wheel bearing..
Post by rfs1957 » Wed Sep 23, 2026 5:35 pm
Split pin was in, but for some reason - I hardly ever use one - I took the nut off with a rattle gun, so I don’t know how tight it was.
I can’t be sure whether it has been untouched for 4 years or 14 ……… I would have to go back and read between 4 and 14 years of notes.
Indeed, sometimes I wonder why I bother writing them :seeingstars:
To save time will get it surface ground back to flat tomorrow, it only needs about 6 thou off it, and the thickness makes no difference to the shimming, of which I’ve got a full set anyway.
However - see below, I don't think it had anything to do with how tight the nut was.
rfs1957
#15 Re: Tolerance for rear wheel bearing..
Post by rfs1957 » Wed Sep 23, 2026 8:15 pm
Ha, be sure your sins will find thee out.
Four years it was.
I was last inside the rear hubs in 2022, and have forgotten already ........... at least, I have pictures doing both hubs in 2022.
Wouldn't these cars be great if you never had to use them ?
Sometimes I think I should call mine Dorian Grey.
The key design aspect of this rear-hub set-up is that the inner race has to be an interference fit on the stub-axle, which is why it is meant to need a press - the effort is to shift the inner race off the axle.
The shim or spacer used ends up hard against the flat face of the collar that is also the oil-seal track,and that collar is trapped by the compression of the nut that clamps the drive-shaft inside the stub-axle.
That same face is also meant to be hard against the back of the bearing, see below.
And no, the collar's face is NOT meant to look like that.
My hub comes apart almost without a press, because the bearing has fretted - through insufficient interference - on the axle.
Therefore the inner race can potentially turn on the axle, like this :
- and in so doing it rubs against the flat-faced collar, which it is not meant to do.
Hence a collar that ends up looking like this - albeit easy to change, or in my case probably surface grind as SNGB haven't got one and I need the car ..........
Has anyone else had this issue with insufficient interference at the bearing/axle interface, and did they manage to make it all work by using bearing-fit Loctite - obviously only upon final assembly, once the thickness of the necessary spacer has been established ?
#16 Re: Tolerance for rear wheel bearing..
Post by mgcjag » Wed Sep 23, 2026 9:07 pm
New hub and bearings for a proper job....but if you need a quick fix you could use a center punch around the worn hub area creating a surface that would need a press to push the bearing back on..and loctite for belt and braces....the punch method was often used on the front hubs to provide a tighter fit to stop bearings slipping/spinning/wearing the stub axel....Steve
#17 Re: Tolerance for rear wheel bearing..
Post by abowie » Wed Sep 23, 2026 11:17 pm
Rory I used a Loctite product on a rear wheel bearing in my Mk2. It is supposed to cope with up to 0.2mm 8 thou spaces.
rfs1957
#18 Re: Tolerance for rear wheel bearing..
Post by rfs1957 » Mon Sep 28, 2026 8:55 am
Consultation with Alan Slawson (Mr Diff) suggests this is a common issue, easily addressed by an appropriate Loctite, and the local machine-shop recommended 638.
So I stole their actual bottle for the weekend, as theirs will be a lot fresher than my own 30-year old one.
As I had already stolen an appropriate length of square tube from them, to then butcher by welding a steel ring to it, so I had a proper support for the hub to use on the press ............. their Loctite went in the cart at the same time.
The jig will go back "tattooed" for future extraction, MOY ARR equals HUB REAR in Forinn' - geddit ?
The interference fit required is probably of the order of 0.01mm to 0.02mm, and mine was around zero, so this should be a piece of cake for a product that claims to be good for up to 0.25mm, and is "Ideal for fixing shafts, bearings, gears, and pulleys."
The trickiest bit is trying to keep grease away from the interface during final assembly.
I don't consider this anything other than a proper job, and would rather make an original hub soldier on instead of introducing pattern parts into the car.
The collar at the root of the problem, and that sits at the root of the half-shaft, cleaned up on a surface grinder at 0.25mm, whilst remaining "hard" according to the machine shop, so I have now gained an extra 0.25mm of negative camber for max-attack in the Pyrenees.
It's obvious, when you pause to think about it, which I am not particularly good at, so I will state the obvious.
When measuring the end-float in those rear hubs, having read that you had to "tap" the hub one-way before measuring the movement, I had assumed this meant you were trying to overcome the "press-fit" of the bearing on the hub - total and utter nonsense of course, that shows zero comprehension of how the assembly works.
You are in fact just measuring the accumulated gaps between the races and the rollers, so pushing in both directions is all that is required.
I did find that having the hub-centre nut tightened to its working torque made a difference, when measuring, on this hub - and tight is tight, the specified value is 20 kg.m / 140 ft.lbs, plus whatever it takes to get the split-pin aligned, which is a high enough torque to make holding half a knuckle-joint in a bench-vice quite some work-out.
I shimmed mine to zero, which is a comfortably ambivalent stance to take, given the raging debate about shimming either as per the original manual figures, in one corner, and adopting the more modern pre-load, in the other.
#19 Re: Tolerance for rear wheel bearing..
Post by mgcjag » Mon Sep 28, 2026 9:22 am
Hi Rory...how will you dismantle with useing 638.......setting the bearing correct it difficult for some and once re fitted back on the car they find too much play and have to re shim....i havent used it so dont know how difficult it is to dismantle......Steve
#20 Re: Tolerance for rear wheel bearing..
Post by mgcjag » Mon Sep 28, 2026 9:33 am
Another solution could be a shimmed tube spacer between the inner/outer bearing.....very similar to that used by some on the front hubs to stop bearings slipping and wearing the stub axels....Steve ps link for the front hub spacer viewtopic.php?f=3&t=17670&p=144317&hili ... er#p144317
