T5 fitting
Paul bow
#1 T5 fitting
Post by Paul bow » Wed Oct 07, 2026 5:51 am
Hi guys, reading some old posts it would seem the T5 from elite is a tight fitment at the front, some have mentioned fouling in the rear gearbox x member.
I have a monocoque metal works internal subframe fitted in mine and any compromise here is going to be a problem (see pics), the steel box section runs across the entire width of the car (same at the rear bulkhead) connecting to the same box section running within the sills, making a H frame.
Has anyone recently fitted one of these, a lot of the posts are over 10 years old and it seems issues with the noisey 5th gear have now been addressed.(?)
Any advice on fitting and what may need trimming/fabricating etc would be greatfully received, just about to buy one with the 0.73 5th to go with the 3.07 diff.
4.2 Semi Lwe, steel tub (best car I’ve ever had !)
4.2 ots (sold)
3.8 (sold)
4.2 2+2 (sold)
#2 Re: T5 fitting
Post by mgcjag » Wed Oct 07, 2026 7:55 am
Hi Paul.....do you use JagLovers forum....lots of info there on T5...it may help?.....Steve
Quattrofrank
Norway
#3 Re: T5 fitting
Post by Quattrofrank » Wed Oct 07, 2026 8:54 am
I have the same hidden subframe kit in my car and I belive everything is hidden under the existing metal so that I wouldnt affect any clearance.
At least I hope so since I have it, and will be mounting a 5 speed to my car as well
#4 Re: T5 fitting
Post by bitsobrits » Wed Oct 07, 2026 5:42 pm
"just about to buy one with the 0.73 5th to go with the 3.07 diff"
I have the .73 5th with a 3.54 diff (so 2.58 overall in 5th) and it's more than adequate for relaxed cruising, but on the edge of marginal for high gradients without downshifting, and with an unnaturally large gap from 5th down to 4th. I would think the .80 option would be the ideal choice for a 3.07 diff (2.46 overall), and would also provide a nice close ratio aspect to the gear changes.
Paul bow
#5 Re: T5 fitting
Post by Paul bow » Wed Oct 07, 2026 8:21 pm
Thank you guys much appreciated..
Bitsobrits..that’s very helpful with the ratios I wasn’t sure whether the 0.8 or the 0.73 would be best suited to the 3.07 diff, so getting that feedback is very useful, no good selecting fifth and it feeling like it’s dropped off a cliff …many thanks👍
4.2 ots (sold)
3.8 (sold)
4.2 2+2 (sold)
Simonpfhc
#6 Re: T5 fitting
Post by Simonpfhc » Thu Oct 08, 2026 7:42 am
Hi Paul,
I have a T5 in mine. Superb gearbox and 5th gear is quiet. I didn’t make any modifications to any metal on the car itself, all I did was to relieve certain areas on the gearbox. I have pictures that I can send to you if you would like. From what I know of the MM subframe, it merely sits within the factory crossmember. So as Quattrofrank said, shouldn’t have any impact.
With respect to the 5th gear ratio, I used an equation that I got from someone who knew Etypes pretty well (can’t quite remember who now!)
“I have found that the 3.8 and 4.2 Jag engines like a combined OD and final drive to work out around 2.5.
example: 3.54 x .73OD = 2.5842
3.07 x .83OD = 2.5481
4.09 x .63OD = 2.5767 ( used in XK 150 type kits)”
I have a 3.31 final drive (ex US) so went with a 0.8 5th ratio.
So my 3.31 x 0.8 = 2.648, is near perfect!
3.31 x 0.63 = 2.085 way too high!
Hope this helps.
62 3.8 FHC
91 Porsche 928GT
#7 Re: T5 fitting
Post by mgcjag » Thu Oct 08, 2026 7:56 am
Paul bow
#8 Re: T5 fitting
Post by Paul bow » Fri Oct 09, 2026 6:16 am
Thank you steve ..
Simon any pics would be a great help, pictures often speak a thousand words!
Many thanks 👍
4.2 ots (sold)
3.8 (sold)
4.2 2+2 (sold)
Simonpfhc
#9 Re: T5 fitting
Post by Simonpfhc » Sat Oct 10, 2026 6:28 pm
Here are some pics of mine after relieving the front upper corners:
I also relieved the area behind the clutch fork as it looked like it might not provide room for full movement. Not too sure it was needed:
62 3.8 FHC
91 Porsche 928GT
Paul bow
#10 Re: T5 fitting
Post by Paul bow » Fri Oct 16, 2026 7:42 am
Simon that’s super helpful, many thanks 👍
4.2 ots (sold)
3.8 (sold)
4.2 2+2 (sold)
