New Member from Florida, USA
kdancy
#1 New Member from Florida, USA
Post by kdancy » Tue Aug 23, 2011 11:26 pm
Hello everyone!
Just found this forum. Working on a 70 S2 FHC and the first Jaguar I've worked on. So far it has been quite an experience! Getting toward the finish line and will have some questions about stuff before we put the bonnet back on.
here is my photobucket album -
http://s294.photobucket.com/albums/mm97 ... to%20shop/
1970 XKE S2
1953 Studebaker Commander hdtp
1953 Hudson Super Wasp coupe
vee12eman
Kiribati
Post by vee12eman » Wed Aug 31, 2011 10:03 am
Hi and welcome,
some very nice and useful shots in there - when do you expect to finish?
Lots of help on here if you ask, I have a Series III, but some info is common and usually someone know something about your problem.
Keep posting the pictures, because it is hard finding info if, like me, your car was dismantled when you started!
Series III FHC
vipergts
Post by vipergts » Wed Aug 31, 2011 11:30 am
That is very tidy work........Superb
Welcome
S1 4.2 Roadster in Resale Red
kdancy
Post by kdancy » Wed Aug 31, 2011 11:34 am
Thanks guys- it's been a lot of work as you can see and we have learned a lot. We are in the process of installing a RetroAir evaporator and find that some modifications need to be made in order to install the radio console. The new evaporator is thicker than the original.
We are shooting to be finished in October.
1970 XKE S2
LLZone
Post by LLZone » Fri Oct 21, 2011 4:10 pm
Welcome to the Forums!
Post by Heuer » Fri Oct 21, 2011 4:46 pm
Welcome to the Forum - some great pictures there. I will jump in (before Angus does) with one obvious but easily remedied error - your bonnet catches are on the wrong way!
They should point upwards when open for safety. My car was 'wrong' as well as indeed is the E-Type Eagle use in their adverts. I should point out that Jaguar fitted them originally the way you have them.
kdancy
Post by kdancy » Fri Oct 21, 2011 6:23 pm
Thanks!!
We were looking at pictures when we put them back in.
1970 XKE S2
