oil leak (onto exhaust)
#1 oil leak (onto exhaust)
hello all can anyone tell the best way to check for the rear crankshaft oil leak. I'm getting oil on the cross member of the exhaust and causing fumes, I'm praying its not what I suspect. thanks johnmack
Series 3 owner
See my answer here: http://etypeuk.com/forum/viewtopic.php?t=2802
Please do not double post as it causes no end of confusion. If you want to create a new thread delete your initial post first - easy to do it is the box with an X in it at the right top of your post.
