You can see the valve lying on top of the radiator top hose in the photo below. It fits in the hole you can see at the top left of the thermostat housing. Water flow to or from it is via the smaller hose you can see towards the bottom left of the picture. This hose just runs parallel to the top hose from the radiator to the thermostat housing.
There is a similar smaller valve built into the thermostat itself in the metal surround at the 12 o'clock position.
The question is, which way round should the bleed valve be fitted? It fits physically in both directions.
Should it be the same way round as the valve which is built into the thermostat?
Or is it's purpose to handle certain conditions where the water flow is in the opposite direction to normal for some obscure reason?
Thanks in advance for any advice.
Dave.
