Post
by Moeregaard » Sun Sep 21, 2008 1:58 pm
That doesn't look like a factory drain plug. I agree with David that pulling the sump and having the hole welded and re-tapped is the best approach. I suspect that installing a helicoil would result in leakage, since these are nothing more than stainless wire having a diamond-shaped cross section. I would avoid a tapered plug at all costs. Once repaired, obtain the correct plug and washer, and don't over-tighten.
There is a very nice alternative to helicoils, known as a "Timesert." These have been popular with the antique-motorcycle guys for several years, and I was able to restored some badly buggered sparkplug holes in my vintage Mercury outboard motor (my other "disease"). The installation kit is a little pricey at $125US, but for repairing damaged threads in alloy these inserts are unbeatable.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
