Post
by MarkE » Sun Dec 07, 2008 9:12 pm
David, if the wood has split because of oxidisation of the aluminium frame, this is a big job if it is to be used on a car again. The wood has to come off, which can lead to further splitting or even its ruin. Then the aluminium has to be repaired, with the oxidised part cut out and replaced in a manner that preserves its structural integrity. Then the wood, or more likely, a new wood, has to be replaced, prepped and varnished.
Wood rim steering wheels are pretty dangerous at best, and are banned from most categories of classic motor sport. If they have a hidden weakness, even a low speed shunt can turn them into dangerous and sharp objects which will hurt a lot if you come into contact with them.
Ask the other repairer how he is going to do all this work. If he?s not, then expect a wheel that has had a cosmetic renovation only?a bit of stained wood filler and a coat of varnish will just make it a pretty wall hanging.
It?s a shame on a lovely wheel like this, but I suspect that the reason Len couldn?t / wouldn?t do it is that he couldn?t do the job properly without destroying the original wood? and that?s the main reason for having the wheel in the first place.
