Misfire under strain
JC
#1 Misfire under strain
Post by JC » Sun Mar 31, 2013 9:41 pm
My SII has developed a misfire under strain - i.e. when I accelerate hard.
An initial inspection of the dizzie revealed a loose rotary arm. Further inspection showed that the advance spring pegs were bent and one was loose - springs were so loose that I was surprised it even drove. I refurbed the dizzie. Still no joy, but the job needed doing.
So I then replaced the other obvious candidates - coil, leads, plugs. Still no joy.
Any suggestions?
JC
vacbag
#2 Misfire
Post by vacbag » Mon Apr 01, 2013 8:57 am
Hello JC.
Check and see if there is water in any of the float chambers, That there is oil in the dash pots and that the vac advance/ retard is working.
Steve.
Steve. Series 2 OTS.
JC
#3 Advice
Post by JC » Sat Apr 06, 2013 7:54 pm
Thanks Steve. I'll give it a go. JC
Dave K
Post by Dave K » Sat Apr 06, 2013 8:02 pm
Rotor arm and dizzy cap should be next on the list.
