66 Etype - remove rear caliper
ScottMHoffman
Topic author - Posts: 12
#1 66 Etype - remove rear caliper
My reear caplier is leaking and sticking and I need to remove to repair. Can this be done with out removing the entire rear suspension?
Scott M Hoffman
1966 Jag XKE
1966 Jag XKE
I don't believe it can be done easily. To remove the rear suspension as a unit is very easy and it might be time to refurb everything?
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
ScottMHoffman
I am removing the rear end and the radius arm bushing are stuck. Any ideas on the removal> I have sprayed with bp blaster but no success yet
Scott M Hoffman
1966 Jag XKE
1966 Jag XKE
Scott
Lots of advice here if you do a refined search e.g. radius AND arm
Here is one thread from such a search: http://etypeuk.com/forum/viewtopic.php? ... radius+arm
Trust it helps!
Trust it helps!
