Although the arms will accept the standard blades (and vice versa) I have decided to give them a go with the Tex blades on the OTS because the stock items are totally useless in the rain. Hopefully the design will make for a better clean sweep. The only way you can tell the arms are not standard is the lack of the two rivet heads on the front. The Tex blade supports are fatter. Seems the Trico arms were factory fit on Ford Cortinas, Lotus, Bristol and Daimler.
So if you are not too worried about concours condition but like to use your car in all conditions these are worth considering. I will report back after the next rainstorm!
Update: The Tex blades are also useless! I bought another set of the Lucas style blades from SNGB at ?16 each and they work perfectly. I also tried three original Trico Aeramic blades and they also work perfectly.
