Oily E-Type
Tony
Post by Tony » Thu Nov 21, 2013 4:35 pm
Rory,
I will check and see if my plug is leaking. I presume I will need some kind of mirror.
Thanks for the advice
Tony (E typed)
Tony
rfs1957
Post by rfs1957 » Thu Nov 21, 2013 9:00 pm
In the motorcycle world we use brake-cleaner / acetone to degrease, then athlete's foot powder spray ........... which will show up the origin of any leak. Happy hunting !
Moeregaard
Post by Moeregaard » Sat Nov 23, 2013 5:26 pm
As long as we're on the subject of garage-floor lubrication, one thing worth having a look at when the cylinder head is removed, is the condition of the camshaft oil-feed threads. Those bolts have been removed and replaced several times over the last 40-plus years, and I learned this the hard way when I reinstalled the freshly overhauled head on my '65 FHC--only to have the alloy threads strip while hand-tightening one of the banjo bolts. Having to pull the head just to install two Helicoil inserts did not make me terribly happy that day!
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
Post by christopher storey » Sat Nov 23, 2013 6:05 pm
Mark - a bit late to tell you, but there is no need to helicoil these. The thread goes much deeper than the bolt, and the Jaguar Enthusiasts Club sell extra long bolts to use the deeper part of the thread even if the outer part is stripped
Moeregaard
Post by Moeregaard » Tue Nov 26, 2013 1:43 pm
Many thanks for the information regarding the longer bolts, Christopher. My data comes from notes I took back in 1991, when the longer items were not available. Still, it's worth having a look at the threads back there while the head is sitting on the workbench.
Mark (Moe) Shipley
Robert Hiland
#26 A possible solution to oil leaks .... and it is cheap!
Post by Robert Hiland » Sat Dec 07, 2013 11:46 am
Try keeping the oil level in the sump at the mid-point of the cross hatch marks.
I found that my leaks were reduced by 75%.
If it doesn't leak, it can't be a Jag
Bob
1967 E Type 2+2
Moeregaard
Post by Moeregaard » Sat Dec 07, 2013 1:46 pm
You can also swap your California-compliant breather assembly with one from an early 3.8-litre car. The Jaguar six has marginal crankcase ventilation at best, and the reduced size of the later breather only compounds the problem by increasing pressure in the crankcase. I did this with my '65 FHC, and after its final engine rebuild in 1991 I had no more oil leaks.
Mark (Moe) Shipley
Peter Harrison
Post by Peter Harrison » Mon Dec 09, 2013 5:53 pm
Hi All, I have had leaks from the rear of my engine and wanted a simple solution. Here is an oil catch-tank system that avoids oil on the drive AND the fumes caused by oil burning on the exhaust. I know from the forum that others have had success with similar designs. PeterH
