I started by using a rough tracing Jerry Mouton made of his original to give me the correct scale (Jerry misinterpreted 'REGD' as a number):
I used this restored example as a further guide and now we know the correct location:
A bit of research revealed the font was 'Stencil Gothic' which I downloaded and used Word to get the correct font size (72 and 36 point) and layout.:
I then trawled the net until I found the correct Trico period logo:
I used Paintshop to add the bridges and pasted it all together:
You can download the PDF file from our Knowledge Base or here:
https://www.dropbox.com/s/0h5bzi89pmro4 ... 9.pdf?dl=1
When printed "Actual size" (do not select fit to page, scale or other option in the print programme) it should be the correct size to have a Mylar (thin and flexible as paper) stencil made. As some printers and various paper sizes can change the scale so you may need to resize the image - width of text from outer edge of 'R' and 'D' on bottom line is 6"". The quote from 'The Stencil Studio' http://www.thestencilstudio.com/ comes out as follows:
All our custom stencils are hand cut from 125 micron Mylar. Mylar is flexible, reusable and suitable for use with any type of paint. Mylar is as thin and flexible as a piece of paper, but strong, washable and re-usable. Mylar is not a rigid plastic. The price is ?15.00 plus VAT Plus P&P. Please note that custom stencils are cut to order, please allow approx. 1-5 working days to cut your stencil plus shipping times as listed above to give you a rough idea on lead times. If you need your stencils urgently then please let us know and we will do our best to meet your deadline.
Contact Clare at the Stencxil Studio if you want a copy: info@thestencilstudio.com
Stencil looks like this (not actual size which should be 6" wide R to D of bottom line):
