Non A/C parts
#1 Non A/C parts
I have a 69 series 2 roadster that I've owned since 1973. During my recent restoration process I converted it from air-conditioning to non-air conditioning. In doing this, I need two parts that are unavailable as far as I've checked. I need the ignition switch bracket that bolts to the steering column. I also need the backing plate for the radio in the center section. The original evaporator unit was just too ugly to install in a newly redone interior. If anyone knows where I can find these parts I would be forever grateful. Thank you.
I have the same problem here. I know that Angloparts have the center radio panel.
Concerning the bracket that fix the ignition switch to the direction column, I'm still looking for it.
1E35547
#4 That is the cover for the bracket I need. Still looking. Th.
osgii wrote:Gilsboy,
this could maybe do the job?
http://xks.com/i-10387413-16-2575-switc ... -type.html
