What sort of plating is recommended
Roger's E Type
#1 What sort of plating is recommended
Post by Roger's E Type » Mon Mar 03, 2014 2:12 am
Hi all,
1966 Series 1 4.2 2 + 2: The exposed parts of the door lock assemblies and the striker plates have a little surface rust and discolouration. I understand that these can be painted or plated.
Is one thing better than the other, and what sort of plating is best?
Cheers,
Roger
ChrisC
Post by ChrisC » Tue Mar 04, 2014 12:40 pm
They should all be Chrome plated Roger, dont think I have ever seen them painted.
1964 FHC 4.2
Post by PeterCrespin » Tue Mar 04, 2014 7:29 pm
No, I don't believe 66 2+2 anti-burst locks were chrome. Cad I think. Bright zinc is fine or whatever floats your boat.
Roger's E Type
Post by Roger's E Type » Tue Mar 04, 2014 11:24 pm
Thanks Chris and Peter for your time.
I'll have a chat with the local platers and weigh things up!
Cheers,
Roger
Post by abowie » Wed Mar 05, 2014 4:14 am
Roger the issue with cadmium plating, which would probably have been what these parts left the factory with, is that the process is quite toxic. As such not many platers offer it.
Zinc plating is an acceptable substitute. Some of the lock parts are diecast though and these will be damaged by the plating process so be cautious.
Roger's E Type
Post by Roger's E Type » Wed Mar 05, 2014 4:24 am
Thanks Andrew for the reply. I wasn't aware that diecast parts were a problem in plating. Can they be masked off to protect them?
Cheers,
Roger
