Oil Pressure
Aldeburgh
#1 Oil Pressure
Post by Aldeburgh » Wed Feb 04, 2009 10:44 am
Once warm my oil pressure dips alarmingly at idle, alomost to zero, but seems pretty good otherwise... 50ish at 2500 and rising as the revs climb. Dip stick showing plently in the system, so why would this be... any ideas?
'73 V12 2+2 Manual. I am on first name terms with every petrol pump attendant in the south of England.
Post by Heuer » Wed Feb 04, 2009 11:38 am
First suspect is the oil pressure sender which is notoriously unreliable. Worth installing the JEC sender and gauge kit (?75) as it is probably cheaper than considering the other candidates (oil pump, big ends). I did a review of the various options in the Restoration/Upgrades part of the forum: http://etypeuk.com/forum/viewtopic.php?t=173
Aldeburgh
#3 ...
Post by Aldeburgh » Wed Feb 04, 2009 11:45 am
Thanks David, you are a sage.
