When they were removed there was quite a lot of sealant (dum dum?) around the joints at the fire wall
Not only was the dumdum around the edges, but it also looked to be between the frames and the bulkhead. This appears to have done a reasonable job of keeping dirt and moisture out of the joints.
Side by side pic. Trial fit of sub frames minus sealant.They weren't particularly careful back in 1970 :-)
My question is this, should the sealant be replaced with a modern equivalent, or should the sub frames just be bolted direct to the firewall dry? I haven't seen this mentioned before so am hoping to get some consensus on what is considered best.
As a supplementary question, what is the general feeling about flat washers under the bolt heads? A number of the bolts screw directly into captive plates and so could likely damage paint when being tensioned.
Appreciate any feedback,
Alan
