A few simple checks before you spend any money:richard btype wrote:Whilst on the speedometer discussion I too have experienced a failure! - I wonder however whether it is the meter itself rather than the drive? Just before the failure a noise was heard which sounded like a spring that was being wound tight and then let go before the noise was repeated.
After about 2 to 3 minutes of this noise which i had no idea where it was coming from apart from the speed side of the bulkhead the noise stopped as did the speedo reading.
I've contacted Speedograph for info on refurbishment which is a reasonable ?55.00 but having read this thread perhaps I'm looking at the wrong end?
1. Remove the speedo gauge ? remove under dash trim panel to right of steering column, squeeze your hand in behind the speedo and unscrew the two thumb wheels securing the gauge to the dash. Unscrew the speedo cable connection. Withdraw the gauge (you'll probably need to pull out the various bulb holders first, noting where they go). Insert a match stick in the cable drive hole in the back of the speedo and turn it by hand to see if the pointer moves.
2. See if you can turn the exposed speedo cable end by hand. If you can it may be broken, disengaged from the speedo drive or the speedo drive may be broken.
3. Withdraw the cable by approx 1/2in and try to turn it by hand ? it should rotate smoothly in the sheath. If it doesn't the cable/sheath may be kinked.
4. Withdraw the Cable completely from the sheath to check for breaks ? it should have a square end at the bottom where it engaged with the speedo drive unit on the side of the gearbox.
5. If all of the above check out okay, remove the seats, centre/radio console and transmission tunnel cover (you have to disconnect the handbrake cable in order to pull the handbrake up as high as it will go so that the console will come off without fouling the dashboard). Unscrew the speedo cable sheath from the speedo drive, unscrew the speedo drive from the gearbox, insert your trusty matchstick in the speedo drive and check that the square drive sticking out of the speedo drive turns freely.
6. If all of the above are okay, the problem could be an internal gearbox fault. Fingers crossed it isn't, and it doesn't sound like it from your description.
Best of luck
