Correct fuel hoses
paydase
#1 Correct fuel hoses
Post by paydase » Sat Sep 13, 2014 5:54 pm
Hi everybody,
May I ask if the black hose in the picture below is correct for a fuel line?
The fuel hose upstream the bowl (yellowish) seems to be original, while the black one between the bowl and the filter is different.
I am concerned because that black hose has small cracks and needs to be changed.
Also these black hoses apparently have been put when the PO installed a cylinder filled with catalyst balls down the fuel filter.
My engine is a 3.8, year 1964. I understand from what I read here that apparently it is not necessary to have such catalyst for using unleaded fuel as the valve seats are already hard enough. If so, it would be useless but would not do any harm either and could stay there. Anybody can confirm?
Serge
1964 (3.8) FHC
1961 OTS
Post by Heuer » Sat Sep 13, 2014 6:15 pm
Should be white nylon pipe which presses on to the unions (no clips).
Available from SNGB and others.
paydase
Post by paydase » Sat Sep 13, 2014 6:51 pm
Thanks David.
So that was incorrect. Surprising and worrying that it was fiited for such an important safety element.
I will make the change.
Cheers,
Serge
Serge
1964 (3.8) FHC
1961 OTS
Post by abowie » Sun Sep 14, 2014 12:40 am
Looks like they have done it so they can put in the aftermarket filter, as there's no filter element in the factory filter.
iani
Post by iani » Sun Sep 14, 2014 7:43 am
I saw a filter that looked like this a while back and, on mentioning it to the owner, he pointed out that the filter was a simple horizontal gauze at the top of the glass bowl. I don't know if this was a standard fitting at some point or not.
Ian
E-type - TBC
1968 Triumph GT6 Mk1
Duckham
Post by Duckham » Sun Sep 14, 2014 3:13 pm
Yes, the gauze is correct on my 63 but they also fitted a paper filter inside the bowl at one stage
Joe
1963 3.8 OTS
paydase
Post by paydase » Sun Sep 14, 2014 4:39 pm
So besides the hoses, my filter arrangement seems to be incorrect :oops:
Is that risky re any dust that may go through the gauze?
Serge
Serge
1964 (3.8) FHC
1961 OTS
Post by Heuer » Sun Sep 14, 2014 6:06 pm
There are gauze filters in the SU's anyway (providing they are still there!) so unlikely to be a problem. However, for the cost involved - new filter element + length of nylon fuel hose - you may as well put it back to the way Jaguar intended.
paydase
Post by paydase » Sun Sep 14, 2014 8:41 pm
Thx for the feedback, David, I'll do that for sure, just a matter of procuring it.
I had not thought of the issue before I saw a picture of correct hoses in this invaluable forum.
I had not understood either the role of the bowl (actually the place of the paper fuel filter), thinking it was there just for decantation of dust/debris, especially because in my car there was another fuel filter downwards the line.
Cheers,
Serge
Serge
1964 (3.8) FHC
1961 OTS
Post by abowie » Sun Sep 14, 2014 10:33 pm
What is the white and green thing clipped to the engine frame with "4 euro" written on it?
paydase
Post by paydase » Sun Sep 14, 2014 10:55 pm
That's the catalyst I was referring to at the beginning.
Apparently not needed but not harmful either.
Serge
1964 (3.8) FHC
1961 OTS
