An alternative is to buy a non E-Type Metallifacture jack off eBay, restore and convert it. This Ford Cortina one cost me ?90 but they sell for anything from ?40 up:
I bought a S1 jack shoe, rivet and spring washer from Richard Smith for ?40 and a can of BS 633 RAF Blue Grey paint for ?11. The spring washer replaces the original which you may have to break to get off allowing you to dismantle the screw shaft and bearings. If you are handy with a welding torch you could easily convert the old shoe yourself and just buy the retaining clip if you need it:
Part way through the restoration:
Grit blasted (?5) and awaiting primer:
Finished:
I need this one for my FHC as I do not want to rely on the Shelley. There is an original E-Type jack on eBay at the moment, albeit with bag, for ?550. Mine will have cost ?125 an will be indistinguishable from an 'original'. 8) To be honest you can just clean, or grit blast if necessary, and paint directly without dismantling.
Note: there are several different styles of Metallifacture jack so look for one with the centre 'foot' and you won't go far wrong. Others will work mechanically but won't have multiplied in value x3 after conversion.
