If you want to mount a big valves cylinder head on your E-type, the next thing to do is find an XJ6 4.2 S3 cylinder head. This is the option I chose on my E-type 66, and which offers 2 advantages:
* The engine runs on unleaded fuel.
* The power gain (probably around 20 hp).
But, we have to do a modification before installation: Recap off 2 water passages that do not exist on the older XK block of E-Type.
For this, I suggest you:
1- Tapping holes (it must be of 12 mm).
2- Install a screw cap with thread lock (red Loctite) and clean.
3- Put some cold welding (resistant to high temperature) on the screw cap and wait 24 hours of drying.
4- Planer everything. If you are careful, you can do it by hand with a ruler (to check the flatness during the operation) without rectification, by filing and after with sandpaper.
5 - You will also need to drill and tap four holes (it must be n?10 UNC) to mount the tachometre sensor and the cap at the end of the exhaust cam shaft, because there is no holes (see first picture).
If you have a serie 1, you will get your cam shafts, especially the right for the tachometer sensor, and the last cam shaft cap near this sensor.
Good luck.
Jacques
