chrisvine
Post
by chrisvine » Tue Dec 09, 2014 12:16 am
The following attachments are templates for the under dash panels for S2 OTS & FHC cars
Note: these have been made from
reproduction cards and traced onto A4 and should be printed as such with no margins. The image contains dimensions to confirm the printed size and the textured side is the outer facing side.
Click for PDF of Card 1
Click for PDF of Card 2
Click for PDF of Card 3
288gto
Post
by 288gto » Tue Dec 09, 2014 1:06 am
Very useful Chris, thanks just downloaded them.
Post
by Gfhug » Tue Dec 09, 2014 9:25 am
Thank you Chris, downloaded. Now with these and photos SimonP sent me of the under dash panels I'll have no excuse for not getting the work done.
- Administrator
Post
by Heuer » Tue Dec 09, 2014 11:08 am
Well done Chris - I will add the links to our Knowledge Base.
Post
by Gfhug » Tue Jan 06, 2015 5:11 pm
Had my first trial fit of cardboard versions. Passenger panel fits nicely. Drivers side took a little more effort, perhaps because of the screen demister pipes fouling against the panels.
Is this normal?
(My under dash is a bit of a mess through PO work, so expecting to extemporise a bit)
Also do the panels fit flush below the dash or slide inside the bottom of the dash?
Can anyone post a photo or two, please?
- Administrator
Post
by Heuer » Tue Jan 06, 2015 5:19 pm
They slide under the lip of the dash between it and the main instruments.
Post
by Gfhug » Tue Jan 06, 2015 5:25 pm
Thanks David.
