Post
by vee12eman » Tue Jan 13, 2015 11:05 am
Hi Claudio,
As I stated, the oil I use is 20/50 and as Peter says, the thicker oil provides more resistance to the pistons rising under acceleration, leading to a richer mix and, in theory at least, greater acceleration. How noticeable is debatable, but easily tested by substitution of the oil. Regardless of the experiences of your mechanic on a different engine entirely, I suggest you compare the performance you have now with thin oil (youe sewing machine oil), with that you get using the factory recommended thicker viscosity.
Easy to remove the oil with a syringe and short rubber tube (which is also the easiest way to top up). Remember, under bonnet temperatures of a V12 E Type are likely to be much higher than those of smaller engine cars, therefore the oil will become much thinner in use due to temperature. Also, as I stated, in an earlier post, the seals in the piston are less than perfect, especially with age; thin oil will only escape faster...
Simon.
Series III FHC
