Speedometer failed
Claudio
#1 Speedometer failed
Post by Claudio » Tue Jan 27, 2015 1:20 pm
Hello Gents, good morning,
My ride with the Jaguar last sunday resulted in a sudden speedometer failure. With no special reason for the cause as far as I can recall.
I cannot precise if the problem is on the instrument or on the speedo cable or on the angle drive that couples the cable supposedly to the gear box. So question: before dismantling the dash panel or the other end of the cable, I would like your comments on where can the problem probably be? I have asked a SNG Barratt representative and he meant thet most usual part to fail is the drive angle (Part C25547). Thank you. Regards. :roll:
Claudio
'73 XKE 2+2 - Yes, I bleed signal red
Post by Heuer » Tue Jan 27, 2015 2:08 pm
This thread may give you some clues: viewtopic.php?t=1601
Claudio
Post by Claudio » Tue Jan 27, 2015 3:25 pm
Thank you Mr Jones.
Kind regards,
Claudio
