Jaguar Suppliers of Component Parts
AC-Delco = spark plugs blower motor, air filter cannister, fuel filter
Acton Bolt Ltd. = U.K. OEM of BEES bolts and screws used on Jaguars in the '50s-'60s, sold to GKN 1962
Adwest Engineering = U.K.-based OEM of Jaguar steering racks, now known as Magal Engineering
Albion Brockhouse = manufacturer of manganese bronze stamped forged spinners (knock-off's)
AUTO = Name found on heads of bolts and screws in some XK120s
Autocalf = Grade of Connolly Leather with embossed grain (see Autolux, Vaumol)
Autolux = Premium grade of Connolly Leather, extra supple with little discernible grain (see Autocalf)
Automotive Products Ltd. = AP, U.K.-based licensor of Borg & Beck clutches, Lockheed brakes, etc.
Bahco = Sweden-based OEM of wrenches in Jaguar tool kits
Bakelite = Early thermosetting plastic used in various Jaguar parts, acquired by Union Carbide in 1939
BEES = Tradename for screws and bolts made by Acton Bolt Ltd. of London, sold to GKN in 1962
Casco Products Corporation = windscreen wipers, cigar lighters and interior mirrors via Tex in the UK
Castrol = U.K.-based OEM of motor oils and other lubricants for Jaguar
Champion Spark Plug Co. = U.S.-based OEM of spark plugs & spark plug caps for many Jaguar models
Cheney = U.K.-based OEM of Double Grip worm-drive hose clamps used on 50s-60s Jaguars
Churchill, V.L. & Co. Ltd. = U.K.-based OEM of special service tools for Jaguar dealerships/agents
Connolly Leather, Ltd. = U.K.-based OEM of leather for Jaguar interiors (Autolux, Autocalf, Vaumol)
Coventry Timber Bending Co. Ltd. = U.K. OEM of Jaguar wood-rimmed steering wheels
CRANES = Name found on heads of screws and bolts used on some 1960s Jaguars
Dana = Dana/Spicer U.S.-based OEM of Jag axles, diffs, cylinder head gaskets, oil coolers, U-joints
Dayco = OEM of Jaguar idler pulleys and bearings
Delaney Gallay Ltd - heater box and heater radiator matrix
Desmo U.K.-based OEM of Jaguar rear view mirrors into the ?60s, early SS Jaguar mascots
Double Grip = Tradename of Cheney, OEM of worm-drive hose clamps used on classic Jaguars
Dunlop = U.K.-based OEM of Jaguar wire & racing wheels, brakes, tires & hoses
English Steel Corporation Ltd - road springs & torsion bars
Ferodo = Italy-based OEM of Jaguar brake pads and drive belts (now a div. of Federal-Mogul)
Furflex = Moquette, velour- or velvet-covered edge trim or ?draught excluder? used on Jaguars
Fray, J. = U.K.-based OEM of Jaguar cast metal badges and emblems
Garrington, John & Sons Ltd. U.K.-based OEM of Garringtons wrenches in some Jaguar tool kits
Garringtons Brand of John Garrington & Sons Ltd., U.K.-based OEM of wrenches in some Jaguar tool kits
Gedore = Germany-based OEM of adjustable wrenches in Jaguar tool kits
Girling, Albert H. = Inventor of SS & Jaguar drum and disc brake systems manufactured by Lucas
Girling, Ltd. = Lucas division combining Girling Brakes, Luvax dampers & Bendix; Jaguar OEM
GKN = U.K.-based OEM of Jag diffs, EAD, ETM, flexible couplings, driveshafts, cast parts, fasteners
GKN Laycock = Successor to Laycock de Normanville, U.K.-based OEM of Jaguar overdrive units
Hardura = Felt-backed embossed vinyl used for Jaguar interior parts
ICI = Imperial Chemical Industries, U.K. OEM of rubber fuel tanks for C- and D-type racing cars
Imperial Chemical Industries Ltd. = ICI, U.K. OEM of rubber fuel tanks for C- and D-type racing cars
Joseph Lucas Ltd. = England-based OEM of Jaguar lighting, electrics, braking & more
Jubilee Clips Ltd. = U.K.-based OEM of Jaguar worm-drive hose clamps (See L. Robinson & Co. Ltd.)
Kelsey-Hayes = U.S. disc brake manufacturer, licensor of Dunlop systems used on Jaguars
King Dick = Abingdon King Dick Tools, U.K.-based OEM of jack ratchets in some Jaguar tool kits
L. Robinson & Co. Ltd. = Firm of Lumley Robinson, inventor in 1921 of worm-drive clamp (Jubilee Clips)
Laycock de Normanville = U.K.-based OEM of Jaguar overdrive units (later GKN Laycock)
Leyland Motors = U.K. OEM of Jaguar XK engine cylinder blocks from 1948, eventually owned Jaguar
Linread = Name found on heads of some bolts and screws on Series I E-Types
Lucar = Brand name of bladed electrical connectors by Lucas
Lucas Industries Ltd. = Successor to Joseph Lucas Ltd., now owned by TRW
Luxan = Dye-enhanced-grain grade of Connolly Vaumol? leather (see Autolux, Autocalf)
Magnatex Ltd. = U.K.-based OEM of Jag quick-release worm-drive hose clamps marked GRIPTITE & TEX
Marston Excelsior Ltd. = U.K. OEM of Jaguar radiators
Metalastik Trademarked rubber/metal bonded isolation bushes & harmonic dampers by Trelleborg AB
Michelin = France-based OEM of tires for some Jaguars
Mini-lite = U.K.-based maker of alloy wheels retro-fitted to classic racing Jaguars
Mintex UK Ltd. = U.K.-based OEM of Jaguar drive belts; brake pads from 50s LeMans winners to today
Moquette = Furlex, velour-/velvet-covered edge trim or ?draught excluder? used on many Jaguars
Moss Gear Co. Ltd. = U.K. designer and OEM of gearboxes used in all Jaguars to 1965
Moto-Lita = U.K.-based maker of classic wood-rim OE and aftermarket Jaguar steering wheels
Newton = Name found on heads of some bolts and screws on Series I E-Types
Nivocode = France-based Lockheed associate, OEM of Jag brake fluid reservoir caps & level indicators
Otter = of Buxton, manufacturer of thermostatic switches
Pilkington Group, Ltd. = U.K.-based OEM of Jaguar glazing, now using Sundym tradename (see Triplex)
Pirelli e C. S.p.A. = Italy-based OEM of tires for many Jaguars
Powr-Lok = Dana/Spicer heavy-duty Limited Slip Differential used in some Jaguars
Pressed Steel, Ltd. = U.K.-based OEM that provided post-WWII Jaguar bodies
Regent = U.K. OEM of Jaguar worm-drive hose clamps
Repton Foundry = cast exhaust manifolds
Reservac = Brand of Jaguar vacuum reservoir tanks produced by Trico
Reynolds Metals Co. = U.S. OEM of 531 alloy square-section steel tubing used in E-Type front subframe
Richards = Tradename on screws and bolts used on 1960s Jaguars, possibly by Richards & Allan Ltd.
Richards & Allan Ltd. = Possibly the OEM of Richards screws and bolts used on 1960s Jaguars
ROS = Name found on heads of screws and bolts used on some 1960s Jaguars
ROT = Name found on heads of screws and bolts used on some 1960s Jaguars
Rubery Owen Holdings Ltd. = U.K. OEM of bolts and screws used on some 1960s Jaguars (E-Type)
Rudge-Whitworth = U.K.-based bicycle-motorcycle maker and OEM of Jaguar wire wheels
Scottish Stamping & Engineering Co. = U.K. OEM of Jaguar crankshafts
Sheffield Steel Products SSP, U.K.-based OEM of wrenches & screwdrivers in Jag tool kits from mid-60s
Shell Oil Co. = Royal Dutch Shell, Netherlands-based OEM of Jaguar lubricants, brake fluid, etc.
Smith, Thomas & Sons of Saltley Ltd. U.K.-based OEM of Snail Brand wrenches in some Jaguar tool kits
Smith-Clayton Forge Ltd. = U.K. OEM of Jaguar crankshafts
Smiths Group plc = U.K.-based OEM of classic Jaguar dash gauges, clocks and instruments
Snail Brand = Brand of Thomas Smith & Sons of Saltley Ltd., U.K.-based OEM of Jag tool kit wrenches
Solex UK = U.K. Division of Solex in France and OEM of the Zenith-Stromberg carburetors
Sovy, U.K. = OEM of Jaguar brake fluid reservoir caps and level indicators (now owned by SNG Barratt)
SPARTS = bolts with pointed ends for easy location
SSP = Sheffield Steel Products, U.K.-based OEM of wrenches & screwdrivers in Jag tool kits from mid-60s
Stockinette = Fabric covering on classic Jaguar cooling hoses
S.U. or SU = Skinners Union, U.K.-based OEM of Jaguar carbs, fuel pumps, etc.
Swallow Sidecar Company = Founded in 1922, became SS Cars Ltd. in 1934, Jaguar Cars Ltd. in 1945
T. Williams Company = T/W or TW, U.K.-based OEM of wrenches in Jaguar tool kits
Tata Motors = India-based owner of Jaguar since 2008
TEC = TE Connectivity (w.s.)
Tecalemit Garage Equipment Co. Ltd. = U.K.-based OEM of grease guns in Jaguar tool kits
Telford UK = OEM of Jaguar brake lines
TEX = Marking on GRIPTITE quick-release worm-drive hose clamps made by Jag OEM Magnatex, Ltd.
Thomas Smith & Sons of Saltley Ltd. U.K.-based OEM of Snail Brand wrenches in some Jaguar tool kits
Timken = U.S.-based OEM of Jaguar bearings (wheel, hub, differential, etc.) (see Koyo, SKF)
Trico = U.S.-based OEM of Jaguar wiper blades, wiper motors (FHP Elmotor), Reservac vacuum reservoirs
Triplex Safety Glass Co. Ltd. = U.K.-based OEM of Jaguar glazing, including Sundym tinted glass
Tuffelt = Thick felt fabric used for sound-deadening and padding in Jaguar interiors
T/W or TW = T. Williams Company, U.K.-based OEM of wrenches in Jaguar tool kits
T. Williams Company T/W or TW, U.K.-based OEM of wrenches in Jaguar tool kits
Vaumol = Trademarked natural-grain grade of Connolly Leather (see Autolux, Autocalf)
V.L. Churchill & Co. Ltd. = U.K.-based OEM of special service tools for Jaguar dealerships/agents
Waxstat = Jaguar OEM cooling thermostats made by Western Thomson Plastics Ltd.
Webasto = Germany-based OEM of Jaguar CC systems, sunroofs, convertible tops, panorama sunroofs
West Yorkshire Foundries = U.K. OEM of Jaguar cylinder heads
Western Thomson Plastics Ltd. = UK-based OEM of Jaguar Waxstat cooling thermostats
William Mills = U.K. OEM of Jaguar cylinder heads
Wilmot Breeden = U.K.-based OEM of brightwork on SS cars and leapers on early Jaguar cars
Wilton Wool = U.K. OEM of Jaguar floor mats
Zenith = U.K.-based OEM of Zenith-Stromberg Carburettors, owned by Solex UK
