Evening all
I spotted a pair of series 2 front callipers for sale and wondered if there is any reason why these could not be the basis of an upgrade to the front brakes on my car....( my originals are too badly corroded to be of any use as it is)
Thoughts welcomed
Jonathan
Using series 2 brakes on a series 1
#1 Using series 2 brakes on a series 1
I'm sure that bolt hole spacing differs and thus you need matching uprights, which aren't cheap.
#3 Re: Using series 2 brakes on a series 1
Volvo 240/244 Girling calipers are pretty much a bolt on option. I bought a set for about 50 quid. There are some minor modifications to do if you want to go down this route but require no more than a power drill. A lot cheaper than 4 new pistons for the originals.265bhp wrote:.( my originals are too badly corroded to be of any use as it is)
Thanks for the advice guys, hadn't appreciated the spacing differences...
...will have a look at the volvo route as well
Jonathan
Jonathan
Yes you need a set of XJs or XJ uprights, axle and bearings which are a lot better in the long run and you can also fit vented discs at the front. You also need new steering arms.tim wood wrote:I'm sure that bolt hole spacing differs and thus you need matching uprights, which aren't cheap.
A lot of bother to be honest, you can buy the whole from Derek Watson including brake callipers and discs for around ?750, I'm not sure but I think E-Type fabs also do a kit.
