I am replacing the ignition switch lock in my series 1 but it seems that it is only possible by removing the copper rivets that hold the back to the front, is this the only way?
Advice appreciated. :?
Replacing lock in ignition switch
#1 Replacing lock in ignition switch
64 S1 4.2 OTS 1E10012 73 S3 2+2 manual 2013 V6 F type OTS
Large hammer and grinder Ian? I can't believe you had to ask!
Not very helpful I know, glad you're back on the car and I'm sure someone will come along shortly with a sensible answer.
I know simon, I have been suffering from grinder and lump hammer withdrawal symptoms for some time, working on the wiring and dashboard I can't find a use for them, until today when a spacer was too thick so I got the grinder out
It has been slow painstaking work doing the wiring, instruments and dashboard but now almost completed :D I will post some pics on the restoration page.
This is the lock I am not sure how to replace without destroying the switch ! :?
If I remove the rivets not sure if that is the only way to replace the lock.
All you have to do is insert a small screwdriver into the hole on the side of the casing and press down the plunger. You can then withdraw the lock barrel.
Voile!
Voile!
