iradek
Post
by iradek » Sun May 10, 2015 9:55 am
Before I strip the car completely I want to establish what was changed by PO.
I want this to be an original car, so your help will be appreciated.
There were so many changes that I am lost.
The car is US specs, Sept 1969 with Power steering and Air conditioning.
Picture 1:
Picture 2:
Picture 3:
Picture 4:
Picture 5:
I suspect the weird button on indicator switch might not be original :)
iradek
Post
by iradek » Sun May 10, 2015 11:07 am
Thanks Heuer, I was not familiar with this site.
I am also reading JCNA Series 2 E-Type Judges? Guide which is very helpful.
The amount of changes Jaguar made only in 1969 is astonishing.
For example I just found out that "on cars with second type air conditioning front fan was deleted and instead two normal fans run continuously, rather then being thermostatically controlled". That's weird, why wouldn't you want for the thermostat to control fans?
- Moderator
Post
by mgcjag » Sun May 10, 2015 11:39 am
Hi Iradek....I also have a 69S2 2+2 UK spec...when u say that u want this as an original car does this mean that u will keep it as US spec with the twin strombergs etc or convert to european spec.....Steve
CTDavies
Post
by CTDavies » Sun May 10, 2015 12:36 pm
Hi Iradek,
the engine bay looks fine to me. I'll have to look it up I think mine is also from September 69.
The cam covers are the right ones for late '69 (without the 'broken' ribs).
The hot water expansion tank should be black and not polished brass, so that's correct as well.
The windshiels washer tank pedestal is also correct and at the correct location althougfh the bottle is missing.
These cars had the narrow data plate and not the big one.
I'm not sure on the ignition parts like spark plugs and cables etc.
Chris
1969 2+2 Series II
Home Restoration
iradek
Post
by iradek » Mon May 11, 2015 8:38 am
mgcjag wrote:Hi Iradek....I also have a 69S2 2+2 UK spec...when u say that u want this as an original car does this mean that u will keep it as US spec with the twin strombergs etc or convert to european spec.....Steve
I'm gonna keep twin strombergs. I want a cruiser for lazy Sundays, not a sports car. That's why I want to keep AC and PS.
How about you?
Riv944
Post
by Riv944 » Mon May 11, 2015 4:30 pm
Hi Iradek
The Facet fuel pump under the bonnet is definitely not original, is it the only pump or is it in series with the SU pump which should be in the boot behind the RHS panel.
Mine is a 69 US spec OTS but which has been converted to three SUs
Ian
E type series 2 4.2 LHD, US spec with 3 SU carb and 2.88:1 diff conversion.
rolando38
Post
by rolando38 » Mon May 11, 2015 8:21 pm
it looks pretty much similar to mine (early 1970)
However I think there should be a black hot water heater fitted to the inlet manifold, introduced in oct 1968
2+2 1970
iradek
Post
by iradek » Mon May 11, 2015 8:35 pm
Riv944 wrote:Hi Iradek
Ian
Yes, the fuel pump in the boot is missing, I am going to get rid of the Facet pump and reinstall original.
How is the performace/economy when you converted to 3 SU? Big difference?
iradek
Post
by iradek » Mon May 11, 2015 8:37 pm
rolando38 wrote:it looks pretty much similar to mine (early 1970)
According to the Originality guide the cross-over pipe was introduced in October 1969 in USA and Canada cars, so mine doesn't have it yet as it's form September
Riv944
Post
by Riv944 » Wed May 13, 2015 7:08 pm
Hi Iradek
The carbs had been changed over before I got the car so I can't tell you if it was better or worse. I prefer the look of the SU carbs though. I did have a previous E Type with twin Strombergs but I couldn't get it to run properly for a long time and I didn't have a lot of free time and it needed much work so finally I sold it and bought a better car.
Good luck with your project.
Ian
